John Deere Model 50 Steering Gear
Camjammer
01-20-2003 15:51:02
Would like to have the print out and instructions for adjusting the power steering gear for a John Deere Model 50 Thank you
John T
01-20-2003 16:57:24
 Re: John Deere Model 50 Steering Gear in reply to Camjammer, 01-20-2003 15:51:02
Dear Cam, even with the manual on those units, its difficult and tricky to adjust let alone try and explain it here in typing. One of the more common needed simpler adjustments is loosening the valve unit on the pedestal and moving it back and forth to center the power left and right, but you may as well break down and purchase what manuals you need because theres a good chance before youre done you may need wiper seals in the lower pedestal and hopefully your pump is ok. Good Luck, Ol John T Nordhoff
Clooney
01-20-2003 16:30:49
Camjammer, you really need a manual, either Deere or I&T. The I&T is cheap [under $20.00] & does a very good job on the P/S complex adjustment procedure. ~There is over 3 pages of adjustment procedure & typing it out would be very time consuming. Even if it were typed out for you here it would lack the pictures needed to go with the text & might not even be correct for your tractor if somewhere along the line your worm has been updated to the late sleeve/worm assembly.
~If you have a specific problem or particular adjustment you need help with we will be glad to answer that for you here..... ...
