John Deere 3020, diesel fuel in the oil
Kevin
01-20-2003 13:50:55
I have a problem with diesel fuel getting into the oil. I'm just looking for some suggestions on what it may be. The tractor has a bad miss and knock to it and is blowing white smoke out of the exhaust. I hope this isn't the beginning of it blowing up.
Kevin
01-23-2003 21:33:15
 Re: John Deere 3020, diesel fuel in the oil in reply to Kevin, 01-20-2003 13:50:55
Thanks to all of you that replied.
Curious
01-21-2003 16:07:21
I agree with twopop - seen bad injector do this fuel in oil & make miss sound
Kevin
01-23-2003 21:50:08
 Re: Re: John Deere 3020, diesel fuel in the oil in reply to Curious, 01-21-2003 16:07:21
Thank for your relpy
Gordon
01-21-2003 06:53:19
Do not run it any more before you pull the pan a bearing could be going tight.Maybe no damage to the crank yet.Check filter {cut it open} and oil on bottom of pan.You might be able to clean crank with it in the tractor.
Kevin
01-23-2003 21:51:39
 Re: Re: John Deere 3020, diesel fuel in the oil in reply to Gordon, 01-21-2003 06:53:19
Thanks for your relpy
MPK
01-20-2003 20:26:11
I had this happen on a 4020 and it was the seal in the injection pump. Most likely you will need to overhaul the pump. It could also be the diaphram in the lift pump.
Kevin
01-23-2003 21:52:27
 Re: Re: John Deere 3020, diesel fuel in the oil in reply to MPK, 01-20-2003 20:26:11
Mike J
01-20-2003 19:39:53
Had a 4010 that got to much ether bent a push rod so the valve on that cylinder didn't close just had to change the push rod.
Kevin
01-23-2003 21:53:08
 Re: Re: John Deere 3020, diesel fuel in the oil in reply to Mike J, 01-20-2003 19:39:53
Red Man
01-20-2003 16:31:37
Usually the fuel transfer pump diaphram goes bad and lets fuel in the oil, or could be the seal where the injection pump mounts to the engine.
Kevin
01-23-2003 21:53:44
 Re: Re: John Deere 3020, diesel fuel in the oil in reply to Red Man, 01-20-2003 16:31:37
twopop
01-20-2003 16:30:07
usually the seals on the injection pump shaft are leaking,or the diaprham in the transfer pump has a hole in it.but the bad miss could be a hole in the piston or broken rings.even possibly a blown injector tip.i would suggest you pull the injector on the missing cylinder and check it.then pressurize the cylinder and see if you get air in the crankcase.
Kevin
01-23-2003 21:54:21
 Re: Re: John Deere 3020, diesel fuel in the oil in reply to twopop, 01-20-2003 16:30:07
