Baker Valve single action cylinder
Dan
01-20-2003 12:48:49
A while back someone asked how to change a Baker valve to use a 1 way cylinde. Finally got a chance to look it up today in my book. On the left side of the valve thee is a block cast onto the valve where outlets come out. On the top is a small pipe plug that goes in at an angle inward toward the valve and down. If you remove that pipe plug there is a short channel and at the bottom of that is a 1/8 inch allen pipe plug. you need to remove that 1/8 inch plug then put the upper one back in. According to my manuel if you don't remove it returning oil will go through the relief valve and cause heat. It also appears that you must use the bottom outlet for the cylinder. Hope this gets to the one who needed it.
