Clooney: Update A govenor and fan drive
TX Denny
01-20-2003 07:19:57
Clooney, the hole was exactly where you said it would be. It goes to the left side of the tractor from the casting and oil should squirt directly on the gear. It was open but not perfectly clear. So the failure appears to be simply that the bearings wore out. Both bearings in the govenor were bad and the bearing on the fan drive next to the govenor was bad. The bearing by the fan on the drive was good. Next weekend, I do re-assembly. Thanks for your help and thanks to others that shared their knowledge.
Clooney
01-21-2003 07:18:54
 Re: Clooney: Update A govenor and fan drive in reply to TX Denny, 01-20-2003 07:19:57
Denny, thanks for the update. Let us know how the tractor turns out when finished?...
TX Denny
01-21-2003 09:11:03
 Re: Re: Clooney: Update A govenor and fan drive in reply to Clooney, 01-21-2003 07:18:54
I expect to get it reassembled Saturday - shouldn't take long. I'm real hopeful.
