4030 or 3020
HA in Oh
01-18-2003 21:34:38
Been looking for a good 3020 diesel, I haven't found one that I'm happy with yet. I found a '75 4030 w/quad and 18/34 rubber, new paint'6200 hrs for $10500. I talked to a previous owner by phone, he said the tractor was good but it had been OH twiced due to the injectors failing and washing down the cylinder. Is this a common problem with these tractors? Are 4030's good tractors? Where they made in Waterloo? Are they hard to start when its cold? How do they compare to a 3020? All input is welcomed. Thanks
Dogdad
01-20-2003 05:42:10
 Re: 4030 or 3020 in reply to HA in Oh, 01-18-2003 21:34:38
HA
I've used 3020's but own a 4030. They are both good tactors, just the 4030 is a little newer and 10 to 15 more HP.
The only problem I have with the fuel system has been jelling when it's cold, make sure when it's -30 below out you got #1 in it.
DOGDAD
Chad Riddle
01-19-2003 10:19:26
I don't have a lot of experience but I ran a 4630 in the early 1970's when I was a hired hand. Their 4020 was a lot better tractor. You should be able to find a real nice 3020/ overhauled/ for 10000. if you want the automatic transmission---the 4020 powershift would be my choice. I have a real nice 3020 diesel synchro-range transmission/ I bought last summer with 4600 hours for 8500. A lot of guys will tell you the 20 series tractors were the best ever built...I'm one of that bunch.
newgen
01-19-2003 06:53:14
The 4030 was made in Waterloo, the 329 engine in it was made in Dubuque.
Terry Clubb
01-19-2003 06:18:03
HA in Oh The 4030 has the 329 engine 6 cylinder engine' plus opitional quad range 16speeds versis 3020 4cylinder 8speed ps or syncro also around 10 less hp than 4030.From past experince I would rather have a late model 3020 if 73hp is enough also a nice 3020 console will probley cost more than a 4030 with out cab. good luck Terry Clubb
