420 Crawler Repair Advice Sought
Larry Hardesty
01-01-2004 19:58:29
I just purchased from my uncle a 1958 420 Crawler that my grandfather had purchased new in 1958. About ten years ago a drive shaft broke and the crawler has sat for the past ten years. One cylinder is pitted and stuck. I welcome advice on how far to have it bored out or sleaving it and where parts are availble. Also, has any one replaced the drive shaft in on one of these crawlers. My uncle tried but it would never fit together completely. Before I go too far, I thought I would ask if there is some trick to it that is not obvious. Thanks in advance. Larry H.
MIKE HANLEY
01-01-2004 20:37:53
 Re: 420 Crawler Repair Advice Sought in reply to Larry Hardesty, 01-01-2004 19:58:29
We just went thought a 430 crawler completly radiator cap to draw bar. all parts are still availble BUT are very very pricey. Yes there are used parts out there but how much better are they then what you already have. MOST IMPORANT thing you can do with the engine is to check the cylinders for out of round. Honeing cylinders and new rings without checking for out of round is a waste of time AND money. Other guys may sat differant and there are many over size pistons on the maket, HOWEVER our John Deere dealer over hauls a lot of two bangers and they will no longer go over .040 on a M MT 40 420 430. Anything over that and they will slive it back to factory. As many as they do in a year,I would put more in what they say then someone who's overhauled one or two in a machine shed. What i am afraid of is that when you tear it down to replace the drive shaft you will find out much more needs replaceing. If this was Granpa's so there is a lot of feeling here and you have in mind to keep it all your life and maybe for your kids. DO IT ONCE AND DO IT RIGTH. No short cuts and no "well we'll get by with that part". Find a place where it can sit for a long time. Get the JOHN DEERE shop manual and start looking for a good local one or two man machine shop. Many of those drive parts and under carrage parts can be built back up and then then machined back to fit new bearings and bushings. If you get into someting that is two pricy, walk away till you save the bucks for that part and then go back at it again. When you are done GRANDPA WILL BE PROUD. Very Proud!! And so will you.
Larry Hardesty
01-02-2004 07:38:28
 Re: Re: 420 Crawler Repair Advice Sought in reply to MIKE HANLEY, 01-01-2004 20:37:53
Mike, Thanks for the advice. The undercarriage looks pretty good. The hour meter says about 1700 hours and it could be right. I know how it was used over the years and probably it was used just a few days each year. It was in the Sandhills of Nebraska which has low rainfall and humidity so the sheet metal looks good. The challenge, which is not inconsiderable dollarwise, appears to be the pitted cylinder and replacing the drive shaft. Just have to see what the things look like elsewhere as we tear into it.
Thanks again. Larry H.
