JD mag
Matthew
01-17-2003 19:09:44
I would like to know if the Wico C mag in the photo adds will work on a styled JD D ?
Clooney
01-17-2003 19:18:34
 Re: JD mag in reply to Matthew, 01-17-2003 19:09:44
Matthew, it depends on the impulse lug length on the Wico C mag you are looking at & what year "D" you have. The early D's used a base mount mag.
Matthew
01-17-2003 19:31:51
 Re: Re: JD mag in reply to Clooney, 01-17-2003 19:18:34
Clooney,my D is a 39,it takes a flange mount mag,the add says its a long lug.Thanks Matthew.
Clooney
01-18-2003 08:24:39
 Re: Re: Re: JD mag in reply to Matthew, 01-17-2003 19:31:51
Matthew, it should work. The "D" takes the same Edison-Splitdorf from s/n 130700 - 152707. So the long lug Wico C should fit.
