Primer ?
jp
01-16-2003 10:34:57
We have acquired some PPG MTK - 2K urethane in John Deere green. Can we prime some of the smaller parts as we get them clean with rustoleum automotive primer without having incompatability problems?
Clooney
01-16-2003 13:30:18
 Re: primer ? in reply to jp, 01-16-2003 10:34:57
Jp, maybe, but using primer not specified for your top coat is asking for problems later. Personally I wouldn't recommend it, but if do use the Rustoleum at least use a good urethane rated sealer before the top coat to help keep incompatibility problems to a minimum.....
Don c
01-17-2003 03:46:27
 Re: Re: primer ? in reply to Clooney, 01-16-2003 13:30:18
used rustolium primer on a couple of pieces and then JD green, looked good, then put part on and when bolts were tightened up paint cracked and chips fell off would look at other primer like clooney said.
Don c
jp
01-17-2003 08:15:38
 Re: Re: Re: primer ? in reply to Don c, 01-17-2003 03:46:27
Ya'll are right. Without knowing for sure about compatbility, we will just paint some of the smaller pieces, brackets, linkages etc., with the spray primer and an enamel that we are sure of and save the urethane for the sheet metal. Thanks.
