MT switch
jp
01-16-2003 09:03:16
third party image
I thought some of y'all might be interested in the insides of an MT Ignition Switch. Does anyone know what the OHM reading should be for the resistor on the back of this switch?
Niner
01-17-2003 06:33:29
 Re: MT switch in reply to jp, 01-16-2003 09:03:16
The resitor should be 2.25 to 2.50 ohms.
jp
01-17-2003 08:08:11
 Re: Re: MT switch in reply to Niner, 01-17-2003 06:33:29
Thanks. I knew it functions in the charging circuit, thus the ohm value is more critical than those required for resistors that merely dim the lights. I've got the one from the tractor and one from the junk yard and both read 2.4 OHMS. Looks like when I'm done I'll have two working switches.
Niner
01-17-2003 06:19:34
Bus Driver
01-16-2003 18:52:50
On the M/MT switches, the resistor is to limit the field current for the generator for the low charge position. These tractors had no dim lights provision in the switch. Suggest get and read an owners manual. Believe it rather than some of the answers posted.
Bill
01-16-2003 16:18:22
jp, can't see your picture. The resistor is just to dim the headlights so it really does it matter all that much exactly what the value is.
jp
01-16-2003 16:26:32
 Re: Re: MT switch in reply to Bill, 01-16-2003 16:18:22
Thanks. The picture is on Parts & Pieces; don't know why it didn't post.
