3 Point Hitch for R, 80, 820, 830
DaveH
01-15-2003 18:09:59
From time to time someone asks if it's possible to put a 3 pt hitch on one of the big diesels. I stumbled across part of a homemade one for sale on Ebay. Just thought that maybe someone might like to see it.
DaveH
Dogdad
01-16-2003 07:01:11
 Re: 3 Point Hitch for R, 80, 820, 830 in reply to DaveH, 01-15-2003 18:09:59
What would an 830 Rowcrop look like if Deere had one more goaround? I am sure that the old boys at Deere had something in mind if the New Gerneration had been delaied. 100hp.+ off the line, factory cab, load sencing three point, 1000rpm. pto.... Could have looked like an 840I in Sound-Guard clothing.
The Dogdad
Steve - IN
01-15-2003 18:48:44
DaveH,
Saw that too. Can you figure out where to mount the cylinder(s) to lift the draft arms?
Steve
DaveH
01-16-2003 04:28:08
 Re: Re: 3 Point Hitch for R, 80, 820, 830 in reply to Steve - IN, 01-15-2003 18:48:44
The only thing that I can figure out is possibly you'd have to use two cylinders - one on each side. There is an eyelet? at the top two corners that you could hook to. Then you would have to hook to the arms at the bottom maybe a foot out. This is just a guess. It would be interesting to see it complete and in operation.
DaveH
Steve - IN
01-16-2003 09:25:17
 Re: Re: Re: 3 Point Hitch for R, 80, 820, 830 in reply to DaveH, 01-16-2003 04:28:08
Dave,
I think the easiest way to get it done is to add two pick up points for two cylinders just above the lower arm pickups. It's a work in progress - that's for sure.
Steve
