G-Man, Sorry if I impunged your handcranking skills. I don't have a crank for my red H - and ain't gonna buy one. The wheel nut is safely loctited on my 60 and I don't have a steering/flywheel adapter. You see, we're not that far from the Dayton Electric Co (DELCO) plant in Anderson and are required to pay homage to Kettering for inventing those electric starter things by using them exclusively (nice excuse, huh?). Seems to me that Farmalls (H's and M's anyway)also came in gas and dual fuel versions - principles are the same. The letter Farmalls without live hydraulics are nearly as clumsy as a hand clutch for loader work. Also, JD A's or B's with rockshafts are a lot easier to convert to a 3pt than an H or M, and maybe easier to convert than a fast hitch on a Super C. Best setup may be to get a B and a red H - the rear rims and tires are interchangeable. What's more, with an A or B you only have to buy 2 plugs instead of 4, adjust 4 valves instead of 8, and you'll never need to split the tractor or work upside down on the clutch, too (we don't talk about how it's easier to stand in one place and set a Farmall's ignition timing, or how you can stand up and adjust valve lash on this forum). Outside of that, a row crop tractor spends 90% of its waking hours going the same speed in the same direction - so the main difference Grimreap will notice is the exhaust note, and that he's got to look on the dash instead of the hood to see all the gauges. It's only when you stop to go backwards or forwards that the clutch placement tests your reflexes (and I also notice nobody has said much about how fun it is to back a wagon with a hand clutch, or the fine art of playing footsie with the hand clutch lever). Steve
