John Deere 720 questions
JD '36 D
01-15-2003 13:51:52
Hi I recently purchased my third tractor( second green). Its a 720 diesel (pony start) rowcrop and I'm trying to figure out the year. Its serial # is 7226410. I think that means its a '58? And what makes a 720 a black dash? Is this one? Another question deals with the pony motor. The pony starts and runs fine if you hold the choke on but as soon as you put the throttle over to run it stalls out. What is causeing this? It worked fine if you held the choke over like i described then we hauled it home and now it stales out when you move the throttle. Why? Could there be something in the carb? I figured I should ask you experts thanks everyone. By the way im only 14 and these pony motors are still a little fuzzy. Matt
Duben
01-16-2003 09:05:38
 Re: John Deere 720 questions in reply to JD '36 D, 01-15-2003 13:51:52
My 730 pony does the same thing when it's low on gas. Fill the tank and it runs fine. There's not much difference in height between the carb. & bottom of the fuel tank. Hope it's something that simple for yours.
plowboy2155
01-15-2003 15:20:26
You might also check the screen in the bottom of the gas tank. Ours was nearly completely clogged.
Clooney
01-15-2003 14:46:42
Matt, I should have mentioned in the other post: make sure the fuel shut-off control that is coming through the dash is open at least 2-3 turns, & seeing as you have the later 720, make sure the oil pressure fuel shut-off is operating properly [or try backing off the knurled knob on the front & holding the knob in while the pony is running to see if the shut off is malfunctioning & not letting enough fuel through]. If you want to check for good fuel flow to the carb you will have to hold that knurled knob in or you will have absolutely no fuel flow to the carb without pony oil pressure..
John T
01-15-2003 14:30:43
Matt, those ponys werent usually allowed to be properly warmed up to get rid of carbon and moisture, and gum carbon and varnish can build up in the carb and fuel system. Needing choke to run tells us its starving for fuel. The first thing I would do is drain the tank and install fresh water free gas. Mine had a small sediment bowl, so see if its clean and water free and see if you at least get a good flow of gas out the tank and any sediment bowl and line. If so, try openign the power needle screw on the carb a tad and see if she runs any better. If you have a good flow of clean gas to the carb and openign the load screw doesnt help (but does run ok with choke), you may want to remove the small top fuel inlet cover off the carb (its been awhile but I think its like that and comes off ???) and clean out the inlet bowl, float and needle assembly. If the inlet and needle and float area are all clean and openign the load screw still doesnt get sufficient fuel to her, it must have a clog inside the carb somewhere. Let us know and good luck. Ol John T Nordhoff in Indiana
Clooney
01-15-2003 14:10:00
JD '36 D, yes it's a 58 black dash.
~On the pony carb; it might just need the load screw opened a little if the weather is colder where you are now. Try opening the load screw about 1/4 turn to 1/2 turn more. It's on top of the float bowl on the far side from the fuel door. If the load screw adjustment doesn't help, you might have to pull the float bowl cover & see if there is junk floating around in the float bowl & plugging the main jet or small by-pass jet. If there is something in there & you don't recognize it, suspect the float [if cork] is coming apart, or the rubber fuel line insides are deteriorating. I have had a few that do what yours is doing & found a beetle in the float bowl & getting sucked into the jet...The other thing I have seen quite often is the rubber fuel line swelling shut inside & blockings fuel flow at high RPM/loads..
