50 oil line coupling plug
Denny
01-14-2003 22:27:08
I need a little help guys. The oil line coupling plug is what the manual calls the plugs you put in to make the 800 hitch work over a hydraulic cylinder. I hope this makes sense. What I need to know is are all of thes plugs the same? ( A,B, and all the number series) I need to buy one and need to know what is right and will work. Thanks, as always Denny
Gordon
01-15-2003 07:56:54
 Re: 50 oil line coupling plug in reply to Denny, 01-14-2003 22:27:08
Ther were 2 different types one is held in place with a shear ring (like an e clip)a nut holds it together the other with a lever. The one that has a hole in the end will lift a ram the other is pluged.There are caps also available those also are different one long and thin the other shorter and thicker.
