Clutch JD2010 gas
Rich
01-13-2003 18:24:59
Is there a cluth adjustment for a JD 2010 gas?
Rich
Gordon
01-14-2003 07:26:25
 Re: Clutch JD2010 gas in reply to Rich, 01-13-2003 18:24:59
Yes there is a lock nut on a adjust cam below the clutch pedal shaft. It takes a 3/4" wrench Loosen the nut and adjust the cam.I forget if right or left side.
james blair
05-28-2005 09:33:36
 Re: Re: Clutch JD2010 gas in reply to Gordon, 01-14-2003 07:26:25
the clutch adjustment nut is a 11/16 and is on the right side if you are seating on the tractor
