David, I forgot the K after the secondary resistance in the first post & didn't catch it on the proof reading... ~The coils primary resistance [points wire to coil ground wire] seems to vary a little due to coil types, whether or not a HD coil & probably supplier. I don't have any exact numbers to give you but somewhere between .5 to 1 ohm sounds close. On the resistance between the center coil contact & ground wire [case], I don't have an exact number on it either, but the Wico "C" usually runs somewhere between 4K to 5K ohms so the "X" should be in that ball park. If yours is open [make sure you are on the K scale] look for a broken ground wire from coil windings to the case ground screw. ~By what you have furnished above it sounds like your problem is either in a shorted points grounding stud [remove the strap between the points & grounding stud sticking through the case],,,or oxidized point contacts [clean or replace the points]... You might want to use your ohmmeter & see if the points are shorted to ground all the time [if so find out why] , or going to ground like they should with the points closed & going open like they should with the points open,,,or if that coils secondary is really open when you measure it again, you have a broken wire [there is a double wire] from the coil windings secondary to ground, or open in the internal coil windings.....
