B Clutch Driver Disk
Ryan
01-12-2003 16:08:57
I've got a 47 early-styled B that I think needs an undersized Driver disk. From Denglers they only have Unstyled and 39 and 40 models. Can I get an undersized one for my B anywhere. Thanks for your help, Ryan
Gordon
01-12-2003 18:39:10
 Re: B Clutch Driver Disk in reply to Ryan, 01-12-2003 16:08:57
You can weld the crank or put shims between the hub and crank. I did that alot years ago.I brassed and filed all the splines back on a B it took the better part of a day but it worked.Today with grinders and wire welders it is faster. The shims work well also cut a tin can in strips.I did this on the flywheel side even on 730D and held. We also just did a 730D about 2or3 years ago with jb weld we are plowing with that one still good.
52BMAN
01-12-2003 17:57:45
Try Sharps Tractor Repair. Web site oldjd4u.com
They can tell you if one is available for your B.
