G Main Bearing torque
Brandon
01-12-2003 09:51:44
I can't seem to find in my service manual what the main bearings should be torqued to on my 51 G. How much do you guys usually torque them? Should I put a little grease on the journals to prevent a dry startup? Thanks alot for the help.
Brandon
Clooney
01-12-2003 11:11:27
 Re: G Main Bearing torque in reply to Brandon, 01-12-2003 09:51:44
Brandon, I suppose there is a torque spec for those main bearing bolts but I don't seem to have any specs on them. I always just tighten them tight then a little more until the pins go in the holes.
~While some people use grease on the bearings I have never liked grease on any Babbitt type bearings & use 40 weight engine oil during assembly. Spin it until you have oil pressure before starting..... ..
