Gas vs Kero
Bob
01-12-2003 05:45:37
Does burning gas vs kero in an allfuel engine make any difference in terms of power output, engine longevity, or anything else other than price and convenience? Just a curiosity question.
35 A
01-15-2003 21:53:09
 Re: Gas vs Kero in reply to Bob, 01-12-2003 05:45:37
I've run A's & B's on kero for years working ground, rakeing hay, belt work, and I prefer it to gas in the summer time. They do what they were made to do, more work on less fuel and I like the smell of spent Kero. They run smoother on kero. than gas as long as you keep the temp. up to 190 or so. Try working ground at night and see the manifold glow red hot and half way up the muffler too. It dosen't get much better than that!
Ron
01-12-2003 06:11:28
The All-Fuel tractors had much lower compression--designed to burn Kerosene.... Using gas is ok, but gas will create much more heat in the cylinders...lead is probably not needed in them because of the low compression.... For best efficiency, higher compression is desireable... All-Fuel JD's have NO heat shields under the fuel tank, and exhaust.I think it would be a good idea to install them....!!!
Bob
01-12-2003 05:49:32
I might mention that what got me started thinking about this was the earlier question about lead additive. If these engines were designed to run on kero, was lead added to kero? If not, then I wouldn't expect lead to be needed in an allfuel engine, even when working it hard. The power output question was kind of an afterthought.
