JD 5020 trans pump noise
Stan
01-11-2003 18:46:48
When I idel my 5020 I hear a constant whining noise from the trans front area. The noise goes away when opeating any hydrolic lever, but comes right back. If it were a bearing I would think I would hear the noise all the time. could the noise be releated to the trans pump? Last fall I used the tractor for about 10 hrs with the same noise and it didnt seam to get worse. Any info appreciated. Thanks
davidval
01-12-2003 01:42:54
 Re: JD 5020 trans pump noise in reply to Stan, 01-11-2003 18:46:48
whine could come from the main hyd.pump drive or from a high pressure hydraulic component.
david
Mike j
01-12-2003 07:12:43
 Re: Re: JD 5020 trans pump noise in reply to davidval, 01-12-2003 01:42:54
I have a 4000 that made that noise when you shut the tractor off for a split second after the tractor stops you could still hear it it was a rockshaft inernal valve leak after about a year it cured it self I think it might of had somthing to do with the adjustment threw the little hole in the back
