John T
01-11-2003 05:16:14
Re: Float Setting on 50 in reply to 50man, 01-11-2003 04:50:05
Hey 50 Man, I had a similar problem on a duplex carb and I didnt adjust the float (That may not be your problem?), heres what I did and it cured it. First, I adjusted each idle needle with the opposite sides plug wire removed at slow slow slow idle by turning them in lean just till she sputtered, and then back out open richer 1/4 turn. Then, I had NO black smoke at idle, which I dont believe in, because it blackens the plugs with soot. Then it had that very slight hesitation when I opended the throttle (but not when setting, just when uner a load), so I opened my power jet settign an additional 1/4 turn, and now Im fine and she idles and runs just where I like her with NO BLACK IDLE SMOKE. If your float is set at factory specs and you have her idling clean, have you tried richening the power jet just a tad??? You might also have a restriction in whats used like an "accelerator pump" circuit. That carb doesnt have any accelerator pump, of course, but it has a well of stored gas that gets sucked up when you crack the throttle, and if its not operative, it can cause what you describe. Also, you might want to check your timing, because that can cause some sluggishness if not set correct. Good Luck and let us know how she turns out. Ol John T Nordhoff in Indiana
