Block sealer
david
01-11-2003 02:22:10
anyone had anyluck using k&n block sealer from napa or any other kind of block sealer? do they work? whats the corect way to apply it? thank you
4020-AL
01-12-2003 08:44:34
 Re: block sealer in reply to david, 01-11-2003 02:22:10
An excelant product if used correctly. We used it on a 7" welded sleeve powerblock on our GM puller. We have had to retreat anually but k & n block sealer is the only sealer that works for us. The problem with it is there can be no ant-freeze solution in the block. The cooling system must be completely flushed of any anti-freeze residue. We run pure water and drain after every use of the tractor. Not very handy, but you have to do what it takes sometimes.
Bill Wy
01-11-2003 19:14:32
Dave: I'm not sure that is was K&N brand but I did use block sealer on a old county dump truck that froze up and cracked the block. I put in the radiator, let the engine run and drained it out a and let it set empty for 24 hour per the directions on the can. It was not leaking 3 years later when the truck was sold.
Gordon
01-11-2003 15:40:55
What do you want to seal?
