G piston ring installation
Brandon
01-10-2003 19:51:28
I have a new set of M&W pistons to put in my G. This is the first 2 cylinder motor that I have ever built. The pistons come with instructions on what groove each ring goes in, but thats about it. The rings that are in the middle (Compression rings), I think, have a small bevel on one side in the inner diameter. Should this be facing towards the top of the piston or toward the bottom? How should I stagger all of the rings? Any info or suggestions on this subject is appreciated. Thanks for the help.
Brandon
Gordon
01-11-2003 16:06:37
 Re: G piston ring installation in reply to Brandon, 01-10-2003 19:51:28
Top ring should be a chrome.
Earl S.
01-10-2003 21:13:30
Inside grooves UP outside grooves DOWN.
Dennis Benson
01-10-2003 20:29:31
See if this is the correct site:
Link
They should stagger about 1/3 turn so that no ring gap lines up.
The top side of the ring is important to get on top, or you will burn unbelievable quantities of oil. The top is designed by the manufacturer, and they should be able to tell you which way the ring goes in.
Gordon
01-11-2003 15:57:08
 Re: Re: G piston ring installation in reply to Dennis Benson, 01-10-2003 20:29:31
They generalty are marked with a dot or the word top on the face of the ring.That faces to the head of piston.
