Correct oil cap for a 1945 A
Randy
01-10-2003 14:08:40
I am restoring a 1945 A and was wondering which cover is correct for where you pour the oil into the crankcase. The one that's on it is a flat lid with the ventilator pipe going up under the hood cover where the battery is. However, I've seen other long nose As with the dome shaped ventilator cover that's like the ones on a G (dome over the pipe which sits on the outside of the hood). I wanted to make this correct since I would be showing the tractor but wasn't sure which one to go with.
Thanks,
Randy
Paul from MI
01-11-2003 13:49:51
 Re: Correct oil cap for a 1945 A in reply to Randy, 01-10-2003 14:08:40
The one on my 1941 long hood A(#509017)has the actual vent tube up under the back panel of the hood. I have owned this tractor for 27 years and I'm pretty sure it's original. The cap that holds the filter in place screws onto the housing. The one Frank sent you is for hand start tractors, but I also have seen a short version of that style used on long hood tractors with starter & lights. I can't remember serial numbers of them, but either style looks like it would interchange. the parts only show the one for hand start tractors for some reason. Probalbly what is there is the original, there's not much reason to ever change one. Paul
F-I-T
01-10-2003 19:11:09
third party image
Randy:
Here a diagram of the breather assembly upto S/N 583999. The vent assy is AA 359 R. It appears to be used for all Model 'A's up to the new, styled models.
Hope this helps.
Frank-in-Tallahassee
70D // 855
Randy
01-12-2003 18:34:28
 Re: Re: Correct oil cap for a 1945 A in reply to F-I-T, 01-10-2003 19:11:09
Thanks for the followup and information.
