JD 420 transmission trouble
Greg Powell
01-01-2004 13:36:31
Looking for advice on a 1956, 420W #109793 with 5 speed transmission. On occasion when shifting out of 4th gear the ball on the bottom of the shift lever seems to jump out of the tops of the shifting forks. Immediate result is that the shifting lever gets stuck in an abnormal position and you are stuck in fourth gear until you pull the top off the transmission and line everything up again. Could it be wear on the ball of the shift lever? Do I need new shifting forks? Could it be the shift rails? I have an I&T manual but it doesn't tell me how to diagnose this problem. Thanks for your help!
Greg Powell
01-02-2004 16:41:00
 Re: JD 420 transmission trouble in reply to Greg Powell, 01-01-2004 13:36:31
Thanks for the advice. I printed out both responses and will break out the wrenches this weekend!
Henry J
01-01-2004 15:01:34
Greg
I think you are getting down to taking the quadrant (thing with the slots in it) off and replacing the stuff that Wayne talked about. Before going into it, you might take the lever to the spot where it seems to always jump into nothing and pull the lever up and down. I would think that would tell you if you are dealing with all the stuff being worn out where the lever attaches to the top cover on the trans. You could do this after removing the slotted cover so you have a birds eye view of where the shifting lever goes through and into the top plate of the tranny.
If you the quadrant seems to be welded to the top of the tranny cover, it probably is not. That thing can get really stuck with rust. I did not get mine off until the shipment of kroil arrived. Then a little heat and a four pound hammer on the wooden bumper and it budged.
Good Luck
Wayne in Tn.
01-01-2004 14:21:08
Greg, first I would remove the shifter guide or quadrant. Yours should have the one with 6 slots in it. Then remove the rubber boot and check the snap ring and bearing, just under the boot. Make sure they are there and are holding the shift lever down snug. Then look on the front side of the shift tower, there should be a lock pin that holds the shift lever snug, if this pin is missing or the holes are worn where it fits, it will cause the problem you have. Also originally there was a spring that run from one side of the shift quadrant to the other, usually these are gone, this is just to help keep the shifter in neutral.
If all the above is tight and in its correct position, you will have to pull the cover and check all the rails, balls and springs.
It is also possible the ball on the bottom of your shift lever is worn, the later models came out with a different design here. Sometimes these can be built up with weld. The later design was an elongated flat ball instead of the round one.
