4230 injection pump
david
01-10-2003 11:01:58
On a 4230 JD the engine would only run at idle, so we checked the filter and changed it. Transfer pump was leaking out the weep hole so we changed it.Now she'll rev up to rated speed but if you slow the throttle either a little or a lot,it will slow down till the engine almost dies and then it will rev back to were you have the throttle set. Fast or slow, it will have to all but stop turning before it will catch and go back to running.Checked the return line and it is not stopped up. Has my governor started to come apart? Thaks, David
mike
01-10-2003 14:43:33
 Re: 4230 injection pump in reply to david, 01-10-2003 11:01:58
Thats what it sounds like, make sure you have good supply of fuel to pump. proably the govener weight retaining ring shot
