730D governer backlash
Nathaniel Watts
01-10-2003 10:27:52
How do you measure the backlash in the fanshaft and gov. shaft gears. I have a new set to be installed to complete my governer overhaul.
Clooney
01-10-2003 13:30:23
 Re: 730D governer backlash in reply to Nathaniel Watts, 01-10-2003 10:27:52
Nathaniel, to properly measure the backlash the heel [backs of the gears] must be even, then mount a dial indicator with the plunger at a right angle to the gear teeth & out near the outer circumference of the gear [I usually use the bevel gear on the governor shaft] & adjust the fan bearing & governor cover gasket thickness give .004"-.006" gear movement. Make sure to keep the heels even when adding shims to one end or the other.....
Nathaniel Watts
01-10-2003 22:43:14
 Re: Re: 730D governer backlash in reply to Clooney, 01-10-2003 13:30:23
Thanks Clooney, this should help me get going.
