Help clooney
Dave
01-10-2003 09:20:28
What do i have to do to get to the brakes on my 1953 JD40? Do i have to take the big nut off in the center of the wheel and what should i be looking for i have no brakes at all.Thanks
Clooney
01-10-2003 13:20:09
 Re: Help clooney in reply to Dave, 01-10-2003 09:20:28
Dave, you didn't say what type of 40? But by you asking about the big nut I will presume it's not a "T" [if a "T" the brakes come apart differently].
~The final drives come apart like Wayne says. Once in there, replace the oil seal on each side as that's usually the reason the brakes don't work. Look for wear on the balls & ball slots in the actuating disks & make sure the springs are good. Those brakes are self applying & if working correctly need very little pressure to start the apply sequence. You will probably find oil in the brake housings, glazed linings & possibly worn balls & actuating disk slots. ~Probably the best thing to do is pull one side apart & see what it looks like in there then post back with specific questions based on what you find.
~If by chance your tractor is a "T" post back as the brakes are serviced differently on the "T"..... ....
Wayne in Tn.
01-10-2003 12:58:55
This is not Clooney, but I have replaced those brakes before. You don't have to remove the big nut. The whole final drive has to be removed, by removing the 4 bolts at the transmission case. You will need to use a sling to pull it, with some sort of lifting device such as an engine hoist or maybe with a floor jack. During assembly you will have to align the final drive shaft back through the brake discs. Also it helps to knock out the freeze type plug on the housing, so you can reach in with a screwdriver to position the brake discs.
Dave
01-10-2003 15:12:16
 Re: Re: Help clooney in reply to Wayne in Tn., 01-10-2003 12:58:55
Thanks for the info Clooney and Wayne oh by the way the JD 40 is a standard.Thanks again
