2755 Power Steering
HA in 0h
01-10-2003 08:42:37
When traveling on the highway my 2755 steering doesn't respond to a slight movement of the steering wheel. You have to over steer it to get it to respond. I don't notice it as much in the field because I'm traveling much slower but it is still a bit noticeable. Also when it is left idoling the steering wheel will continuely turn on it's own. Thanks for any input.
G-MAN
01-10-2003 10:41:03
 Re: 2755 Power Steering in reply to HA in 0h, 01-10-2003 08:42:37
Does your tractor have a Sound-Gard cab on it or is it open-station? The steering systems are different on the two types.
HA in Oh
01-10-2003 12:24:17
 Re: Re: 2755 Power Steering in reply to G-MAN, 01-10-2003 10:41:03
This a open station tractor.
cannonball
01-11-2003 07:32:14
 Re: Re: Re: 2755 Power Steering in reply to HA in Oh, 01-10-2003 12:24:17
probably your lever bearing are gone...check the bolt that holds the arm (the one drag link ties too)..make sure it is tight... have someone move steering wheel while you are on ground and watch drag link, you will probably see the lever ( they call it) move in housing before it moves wheel..they want and arm and leg for the levers..i press the rod out and have them made..last one was made out of hyd cyl shaft, wanted to see how the chrome held up...have nice day may god bless
HA in Oh
01-11-2003 10:54:17
 Re: Re: Re: Re: 2755 Power Steering in reply to cannonball, 01-11-2003 07:32:14
I should have said that this tractor has hydrostaic steering, the unit has hydrolic lines running to two steering cylinders that are attached to the front axel. Thanks for all input.
