730 gas power (I am new to John Deere)
John
01-09-2003 18:11:21
I am new to John Deere and I really don't know much about them. I was wondering what kind of power you can get out of a 730 gas. Is their a power block for a 730 or a power block that will work in a 730? What is the max bore you can have in a 730? Where would be a good place to get a few high performance parts for a 730? Any other tips or info would be appreciated. Thanks
BIG IRON
01-13-2003 16:46:16
 Re: 730 gas power (I am new to John Deere) in reply to John, 01-09-2003 18:11:21
John,
I was interested in the same type of information you are, but mine is a 70 gas. I had a cam shaft ground for stock RPM but with more lift (Berry Cam Service 320-395-2377, Minnesota, $140). I ported the head and intake manifold myself as well as mill the exhaust manifold. I added a dry element air filter. The head and block had 1/8" each taken off for compression reasons. I ended up with 67hp on pump gas, stock size valves .450 over gas pistons(used), and stock stroke. I still want to bore out the carb, add electronic ignition, and change the rocker arm geometry. realisticly I should be able to get 77 hp from this combonation. I started with 47 hp. My phone # 507-787-2345 at work. Don't spend big money on the power block and stroke when the breathing improvements alone make a big difference and cost alot less.
Gordon
01-12-2003 18:11:38
I made an error.The shift pattern is 1,3 on top nexted down R,2,5 next down4,6, This shift pattern has the creep gear in sorry adout the first letter they have differnt patterns on differnt tractors.
Gordon
01-10-2003 17:56:06
The tractor is about 55 hp. The trans can make a big diffrence there is a standard and one with a special 5 gear. On the standard 1st rev 3rd are on top. That has the creeper gear.It is not hard to change the special 5 back to standard it is all on the outside of tractor.
