Diff between 720 D and 70D engines
Les
01-09-2003 18:07:26
Got a book that says that the 720 series offered entirely new engines over the 70's, except for the 720 Diesel. What does this author mean? Do the 720 D's have the exact same engine as the 70D? Or are some parts different?
The book is: JOHN DEERE TWO CYLINDER TRACTORS BY ROBERT PRIPPS.
Thanks, Les
gene
01-10-2003 20:00:22
 Re: Diff between 720 D and 70D engines in reply to Les, 01-09-2003 18:07:26
from what i remember the 720 they went to a pressure fed oil bearing on the center journal of the crank in the 720's an if i am not misstaken the they went to a heavier rod in the the 720's
johndeeregene
JDGnut
01-10-2003 14:55:25
As other have listed basically the same engine... Different bowls on the pistons.. but most have been changed to the later bowls style.. the later ones had different pumps and injectors.. 10mm pumps in the 70D.. 13mm in the 720s.. Also a change in the injectors tips.. I don't remember when the change came on the head.. but I believe it was in the 720's.. I know the 730s had a better designed head than the 70D.
JDGnut
Les
01-10-2003 08:22:27
Also wondering about the 720D and 70D flywheels. Would they interchange?
Clooney
01-10-2003 13:42:36
 Re: Re: Diff between 720 D and 70D engines in reply to Les, 01-10-2003 08:22:27
Les, the early 720D [under 7214899] should interchange with the 70D [unless the later parts were installed on an early 720D. The 70D & early 720D used the F-1933R flywheel. I haven't ever tried to use the later flywheel on an early tractor so can't say whether it can be made to work or not....
Clooney
01-10-2003 03:37:26
Les, the late 70D & early 720D were about the same engine & used most of the same parts. As the 720D progressed it kept getting improvements & became slightly different than the 70D..... ...
JD Guy in NE
01-09-2003 18:36:36
from what I remember, the heads & injectors were different, and I think the later 720's may have had piston heads that were shaped differently, but I'm not sure on that one.. I'm sure you'll get more accurate comments later on..
