Clooney 60 trans question.
Chris
01-09-2003 15:41:28
Clooney,
My 60 does the same as the fellows 620 below. When coming from the right side of the quadrant back to the left sometimes i have to go over into a gear then back out and it will work. If i decide not to go into the tranny and live with this am i taking a chance of tearing anything up. Thanks Chris
Clooney
01-09-2003 16:04:01
 Re: Clooney 60 trans question. in reply to Chris, 01-09-2003 15:41:28
Chris, that is a hard question to answer. It would depend on what the problem is. If just worn shifter parts or mis-adjusted shift rails it won't cause any long term problems, if due to worn bearings or counter shaft end play it will probably keep getting worse with time. If you decide to use it [as is] keep tuned in for new & unusual noises, & if the trans noises get worse or change it would be time to "go in".
~On most I have seen with problems like yours I almost always find worn bearings in the trans when I finally tear it apart .....
