John Deere A Magneto Timing one more time
Bob Albers
01-09-2003 10:28:11
My A is a 1947, styled, pressed frame, starter on the bottom, old two range transmission. The fly wheel is marked LHTDC. I assume this is the same as LH IMPULSE that it talks about in the book. When on the 3 o-clock mark, it is in fact at top dead center and factory marks on the cam and governor gears line up and the magneto drive is horizontal. Am I correct in this assumption? and why is my flywheel different? (it has the correct casting number) I also have a set of degree marks on the edge of the flywheel close to the starter ring gear. When set as above, these marks are roughly at the 11 o-clock position. I assume these are for timing, but there is nothing in the books and I don't see any stationary reference mark for them. Does anyone know what they are for and how to use them? they sure look like factory marks. Thanks, Bob
Clooney
01-09-2003 12:43:02
 Re: John Deere A Magneto Timing one more time in reply to Bob Albers, 01-09-2003 10:28:11
Bob, it sounds like you have a late 47 "A" with either a replacement, or a J.D. 60 [A-3264R] flywheel on it. The later flywheel will have the timing marks on it but will carry the same part number as the earlier ones..
Gordon
01-09-2003 11:00:36
When the flywheel cover is on take the center cover off. You will see a punch mark on the flywheel and a mark on the cover. Are you sure it is lhtdc or is it lhex left hand exaust.
