Hard starting 1928 D
Dominic Centonz
01-01-2004 12:25:59
I drove my 1928 model D into a building 2 years ago. Yesterday I took it out and it would not start. I checked for spark and it was excellent. When I poured gas into the primer cup it would fire on that, but not keep going. I pulled the carb, saw rust in it, cleaned it out real well and tried again. Now it will fire for about 2 or 3 times on its own, but die out. I'm getting too old to turn that giant flywheel much more. Any suggestions on what's wrong? It always started this way before.
John in Md.
01-02-2004 02:08:19
 Re: Hard starting 1928 D in reply to Dominic Centonze, 01-01-2004 12:25:59
Get a chain and your Super C and start dragging. But first drain your old gas and replace with fresh gas with some dry gas or shellac thinner added.
I once bought an Unstyled B that would only start if I belted it up to another tractor. But most would say that's unsafe now, funny how times have changed, but it sure works.
Van
01-01-2004 13:12:33
Drain that stale gas out of the tank and get some good gas. It will probably start then.
Ken
01-01-2004 13:04:06
Remove the fuel supply line to the carb and make sure that you have good flow, if not, check the screen in the tank. If flow is good check to see if the float or needle valve are not stuck in the closed position. Hope this helps. If there was a lot of rust in the carb, it probably came from the tank which tells me that the screen could be plugged.
