Crankshaft woes in 70 LP
snowmantn
01-09-2003 09:30:05
My friend just bought a 70 LP. Nice barn tractor that has been run in a couple of years. Here's the bad part, the flywheel is welded the the crankshaft and it has a little too much end play. Not knowing for sure what we will find under the welds but expecting the worst can the slines be repaired and will a gasoline crankshaft work in this tractor. He wants to leave it on LP. What is involved in checking the regulator and carb on an LP that has been sitting for 2-3 years. I have very little experience with LP tractors and do not want to take the hard knocks course in flammable LP gas. Thaks for any advice.
snowmantn
Clooney
01-09-2003 12:56:51
 Re: crankshaft woes in 70 LP in reply to snowmantn, 01-09-2003 09:30:05
Snowmantn, you will probably find the crank splines & flywheel torn up when you cut those welds loose. If the end play isn't real excessive why not just leave it until you have to remove it.
~The gasoline crank is different than the LP crank due to the LP crank being a little stronger. The service crank for both the gas & LP was the stronger LP crank. If you aren't going to work that LP tractor real hard, the gasoline crank will hold up good.
~I don't know what to tell you on the carb & regulator. Probably check the carb for rust & plugged passages & check the regulator & fuel lines for leaks. If something doesn't work correctly or leaks then it will have to be repaired as it becomes a problem...
snowmantn
01-09-2003 22:18:24
 Re: Re: crankshaft woes in 70 LP in reply to Clooney, 01-09-2003 12:56:51
Thanks Clooney, we had to get the starter rebuilt and reinstalled today. Now we found we have a small firing problem to fix tomorrow. Are the LP carbs similar to a gas carb as far as inspecting and cleaning? Thanks again.
snowmantn
snowmantn
01-09-2003 09:32:20
Sorry I meant that 70LP has NOT run in 2-3 years. Thanks.
snowmantn
