JD B water pumps
Frank Weisel
01-08-2003 19:16:12
Can a water pump be added on a 49B and where can you get them?
Thanks,
FK
Mark
01-08-2003 19:34:00
 Re: JD B water pumps in reply to Frank Weisel, 01-08-2003 19:16:12
Frank,
The water pump was added to the B at serial number 306600 (1952 model).
You will need the lower radiator tank, pump, and lower water pipe. Salvage yards are probably your best bet. Some of the parts from a 50 and possibly other tractors use the same part numbers. You will need to do a little part number research.
Good luck,
Mark
Gordy Mn.
01-10-2003 17:39:01
 Re: Re: JD B water pumps in reply to Mark, 01-08-2003 19:34:00
Just a question, I have a 51 B serial 282674 that has a water pump and it was from the factory. Any coments?
Gordy Mn.
ChuckW
01-08-2003 19:33:07
restoration supply list one in their catalogue, however you will have to change the bottom tank on your tractor and add a longer fan belt. It will work.
