46 D main bearings
Mikey G
01-08-2003 18:21:05
A friend called me today with a question I cant help with so all help is a plus > He is rebuilding a 46 D and is replaceing the main bearings I dont know where he got the inserts but when you install them in the caps they protrude about 20 thou above the caps. Is this correct ? If you then shim the caps for clearance do you leave the 40 thou. between the caps unsupported? this dosent seem right.
Thank you All
Mikey G
