50 JD HOOD
LUKE
01-08-2003 17:58:40
I AM TRYING TO TAKE THE HOOD OFF MY 50 TO STRAIGHTEN SOME DENTS. DOES THE GAS TANK HAVE TO COME WITH THE HOOD?
Larry W.
01-09-2003 06:19:13
 Re: 50 JD HOOD in reply to LUKE, 01-08-2003 17:58:40
You can take the fuel tank off the hood and leave it in place when you remove the hood, but it is a tough job getting it back together. It is much easier to take the fuel tank with the hood during removal, and then reassemble with the hood upside down on a padded surface. Alignment of the fuel tank to the hood and brackets is a real tough job with the tank mounted on the tractor.
John Van Valkenburgh
01-08-2003 20:06:53
When I removed the hood on my 50 I took the gas tank off with it. I seem to recall that the tank is bolted in place on a pair of flanges which are part of the hood. You should be able to unbolt the tank once the hood/tank assy is removed from the tractor.
You will find it easier to remove the hood if you drain the gas out of the tank first.
Good Luck,
John
