 Just couple of other comments. The pony exhaust also exited through a heat exhanger in the diesel engine intake, so the intake air for the diesel was also pre-heated for starting. The '70' Diesel introduced the V-4 starting engine, and it used a single control lever. All the way aft engaged the pony starter pinion with the diesel flywheel ring gear, and operated the decompression lever, which held the exhaust valves open about .055-.080". Just enough to keep the load of cranking off the pony. When you moved the single lever forward to a detent, the decompression lever was released, and full compression was restored. Then you advanced the diesel throttle off the stop, and the diesel engine would start. There was an overrunning clutch within the pony transmission to prevent the diesel from over-spinning the pony as it started. Then you pushed the lever all the way forward, and shutdown the pony. The earliest model '70'D's used an ultra forward position to actuate the pony electric starter motor, but it was abandoned for a foot pedal on later '70'D's. In the photo, you might just be able to make out the pony sitting on top of the tractor, just forward of where the dash would be. Frank
