JD 2440
Scott
01-08-2003 06:24:10
Looking at a 2440 for general farm work, mostly mowing. Not familiar with this model. Would like to add a loader. Any experience good or bad would be appreciated. Appears to be a pretty good local tractor. Dealer is asking $8500. Is that reasonable?
Scott
JD70Jim
01-08-2003 08:21:38
 Re: JD 2440 in reply to Scott, 01-08-2003 06:24:10
Is it the Dubuque model or the Mannheim model? While most of the 40 series John Deere utilities were built in Germany, the 2440 and 2640 were both built in the US at Dubuque from 1976 until 1980. The 1980+ tractors have different styling and are likely different in other ways also. I have a 1976 model 2440. It is a good little loader tractor. Ours has a 145 John Deere loader on it with the separate hydraulic spool so you don't tie up the rear scv outlets with the loader.
How many hours does it have, and what condition are the tires? How many SCV? What transmission options (reverser? Hi-Lo?) does it have?
Offhand, without a loader already on it (unusual) the $8500 asking COULD be a good price especially if the tractor doesn't need rubber and has the goodies, I have seen 2440s advertised for $11,000 all the way up to $14,500 but with a John Deere loader already mounted. I have also seen a 2640, with canopy, small clamshell fenders and 26" rear rubber sell for under $9000.
The 2440 and it's kin do sometimes develope internal hydraulic leaks, and while fixable, until they are fixed, if the tractor has the leaks it will be troublesome. The Brakes, steering, differential and tranny all work from the same hydraulic pump and reservoir.
I would ask the dealer about this if I were you. If the tractor has a sound hydraulic system it should be just fine.
Scott
01-08-2003 10:54:30
 Re: Re: JD 2440 in reply to JD70Jim, 01-08-2003 08:21:38
Thanks for the feedback. I do know this is a early 70's model, so it's probably Iowa built. I am going today to check it out a little more and get all the details. Will try to get back to you tomorrow.
SC
John
01-08-2003 13:15:05
 Re: Re: Re: JD 2440 in reply to Scott , 01-08-2003 10:54:30
The 2440 came out in 76. I bought a nice used 1978 about 8 years ago for twelve thousand. Only had 400 original hours on it. I put a 48 deere loader onit for a bit then moved up or sideways possibly with a 620 deere. I liked the 620 for its quick tach setup so I can switch frombucket to forks in a minute or less. Have 1100 hours so far and its been a good piece.
