BORING JD 70 GAS to 6.125
Old Joe
01-01-2004 09:43:57
Just wondering if anyone has bored a 70 gas block to 6.125 and used standard model G pistons or what would the max over bore be for the 70.
Thanks Ole Joe
tractorboy
01-01-2004 17:39:32
 Re: BORING JD 70 GAS to 6.125 in reply to Old Joe, 01-01-2004 09:43:57
If you are real worried about your block try to find a 70 all-fuel block. They had the bore your wanting from the factory. You might want to get head and exhaust and intake pipes. I have been told there is a differance in block length but I'm sure somebody knows the specifics.
Old Joe
01-01-2004 17:47:04
 Re: Re: BORING JD 70 GAS to 6.125 in reply to tractorboy, 01-01-2004 17:39:32
Thanks for your input, but I checked into the 70 all fuel block and it's like you said you have to get the head and all the other pieces because it is different than 70 gas and that makes it an expensive adventure unless you can find a parts tractor with all the parts you need still on it. And besides all fuel parts are hard to find.
Old Joe
Earl S.
01-01-2004 16:00:39
Call Jerry Hinrichs at 815 778-1900 or 815 499-6580 . he has the spec and he has the pistons . Earl In Illinois
Earl S.
01-01-2004 10:56:28
Yes we bored (5.875) bore 70 gas and LP to 6.125. M&W part #AP 141 for 70 Gas pistons 6.125. M&W part # AP 143 for 70 LP piston 6.125. Earl In Illinois
Old Joe
01-01-2004 13:23:11
 Re: Re: BORING JD 70 GAS to 6.125 in reply to Earl S., 01-01-2004 10:56:28
Thanks Earl for the information, I tried to find M&W on line and ran into an ad that said they were bought out and no longer make tractor pistons. This is the piston I'm interested in M&W part #AP 141 for 70 Gas pistons 6.125. or would a standard bore G piston work in the gas 70 or is the design of the G piston one that cannot be used in the 70 gas? Thanks Again
Eric
01-01-2004 13:44:48
 Re: Re: Re: BORING JD 70 GAS to 6.125 in reply to Old Joe, 01-01-2004 13:23:11
measure from center of the wrist pin to the top of the piston if it is the same it will work if it is longer you can turn it down if its shorter I probably would look for the M&W pistons
Old Joe
01-01-2004 13:54:40
 Re: Re: Re: Re: BORING JD 70 GAS to 6.125 in reply to Eric , 01-01-2004 13:44:48
Thanks Eric, but I do not have a G piston and I do not have the pistons out of the 70 at this time. I was hoping that someone out there might know the differences in the two pistons. I have a vertical mill and lathe so I can modify the G piston if it would physically work. I was hoping someone could give me the deminisions of the two pistons like compression height, ring placement, dome configuration and reliefs for valves and spark plugs, if any. Thanks appreciate your input.
Eric
01-01-2004 16:02:51
 Re: Re: Re: Re: Re: BORING JD 70 GAS to 6.125 in reply to Old Joe, 01-01-2004 13:54:40
If you are that mech. inclined you can make it work. Have you ever heard the term stretched rod? If the G piston is too short you can cut the rods add a piece and weld them back to get exactly the right compression ratio. I have a set of G pistons and could measure them for you but do not have the 70 ones. If you need my set we could work out a deal because I dont need them. I know both pistons are concave on top and very much the same configeration,.you can machine them till they are flat tops and they will not interfere. You can raise the compression ratio to 8.5 and still run regular gas.
Old Joe
01-01-2004 16:17:15
 Re: Re: Re: Re: Re: Re: BORING JD 70 GAS to 6.125 in reply to Eric, 01-01-2004 16:02:51
Thanks again Eric, Are your G pistons standard? What condition are the pistons and pins in and what is the bottom dollar your asking for them?
Old Joe
Eric
01-01-2004 19:00:17
 Re: Re: Re: Re: Re: Re: Re: BORING JD 70 GAS to 6. in reply to Old Joe, 01-01-2004 16:17:15
Ill try to look them up tomorrow an reply. If they are good 25.00 each and you pay freight.
