Help with Prestolite Distributor
Mel Anaya
01-08-2003 06:16:40
Need help I have a JD1010 with a prestolite
distributor, I need the plastic insulator where
the points and condenser tie together. My JD parts
man says no longer available. Does anyone know
of a supplyer where I can buy this part.
Please any help
Thanks Mel
Chuck W
01-08-2003 14:29:00
 Re: Help with Prestolite Distributor in reply to Mel Anaya, 01-08-2003 06:16:40
I purchased the point assy a couple of years ago...probably just the one item isn't available but the assy should be available and it was reasonable.....check again with the dealer...they use the same thing in combine engines....
Mel Anaya
01-08-2003 09:49:28
Thanks for the reply Earl has a supply
Mel
ET
01-08-2003 09:28:35
I got a complet breaker plate asembly for one in a 2510 last year from a fellow that rebuilds starters and generators. He had acess to prestolite parts. You will need the prestolite part number.
Earl S
01-08-2003 07:20:44
Do you have dist # I have break down of Prestolite dist. but not by application.
