JD 310 Backhoe
John McNamara
01-07-2003 11:13:10
Having a hard time starting it...Is there a glow-plug switch? (diesel)....Looking for an injector pump.....
Paul Ostrander
01-12-2003 15:41:40
 Re: JD 310 Backhoe in reply to John McNamara, 01-07-2003 11:13:10
I have a 310a backhoe with about 6000 hours on it. If the temperature is below about 60 degrees, I have to plug in the water heater or use ether. I do not think you can expect much better from that model.
cannonball
01-08-2003 16:03:48
does front pump have bypass screw on it, if so use it, if not move steering wheel back and forth while cranking it, does it have 2 batteries, is starter in good shape. is fuel filter clean, is booster pump good ...could be lots of things, but try by pass if it has it...have nice day may god bless
Jonathan
01-07-2003 12:48:15
There are no glow plugs on a 310...Does it smoke when cranking over ??? crank over too slow ??? any other info .....an injection pump probably won't cure the problem ....
