Clooney help
Mark H.
01-01-2004 07:38:22
Happy New Years, Mr Clooney I was wondering if there is a advantage to a higher compression in a pulling tractor with a govenor set at 110%.To me it seems you would get more power from a bigger bang.
Thaks in advance
Mark H.
Clooney
01-02-2004 05:53:00
 Re: Clooney help in reply to Mark H., 01-01-2004 07:38:22
Mark, I'm not a puller so can't comment on how much you will gain from more compression but up to a point higher compression will add horsepower & more pulling power.
~There are so many related issues involved, & raising your compression is just one of the issues.. You also have to get enough fuel & air to the engine, then will probably then need a hotter spark to ignite the mixture under that higher compression..
~Your best bet is to find someone in your area that has a competitive tractor like yours & see if that person will part with any of the information on his set up..
~If your tires are spinning out now adding more compression or horsepower won't help.. You have to get the traction set up first then find enough power to use that traction...
