720 reduction cover
KEN C.
01-06-2003 19:51:00
I changed some gears and am ready to put on the reduction cover. Is there anything i need to put on first to do with the clutch, or can all the clutch parts be put back on afterwards. I read the other day about someone doing this and had to take back off, trying not to have to do that. Thanks, Ken.
Ben.So.Tex
01-07-2003 04:34:48
 Re: 720 reduction cover in reply to KEN C., 01-06-2003 19:51:00
Ken, Don't forget to put the spacer in behind the out side bearing, I had to pull mine off last week again, when I could not get the cotter pin back in,I was trying to put the spacer in the wrong place, lucky for me I did not have the clutch on.Good Luck Ben
Clooney
01-07-2003 03:48:07
Ken, don't forget the cam bearing spring between the cover & R/H cam bearing. Don't install the input shaft [drive gear] outer bearing until after the housing is installed. Be very careful when installing the cover that you don't jamb the small idler gear [oiler gear] in the lower cover when installing the cover. If you are using the new type multi-piece cover gasket make sure to use sealer on the joints. I usually glue the gasket to the cover & use sealer on the whole gasket. If you have the late cover, leave the top & bottom little clutch stop bolt access covers off until after you install the pulley & clutch parts so you can set the clutch fork stop bolt clearance.
