2010 Row Crop info
Ed Resto
01-01-2004 07:17:58
I have a 2010 RC gas tractor, a 1963 model, serial # 36562. It has the n/f with roll-0-matic, power steering, and I have yet to see another listed that has power adjust wheels like an Allis, with 13.9x36's. I've heard that the n/f row crops were only produced 1 or 2 years. I'd appreciate any help in narrowing down the production figures on this tractor. Thanks Eddie
MIKE HANLEY
01-01-2004 11:14:27
 Re: 2010 Row Crop info in reply to Ed Resto, 01-01-2004 07:17:58
No the 2010's were made in both rowcrop and utilitys from 1961 (made in 1960 for the 1961 model year) starting with serial # 10001 through 1965 starting that year with serial # 58,186. Your serial # would be a 1963.
The utility verision was the 2010 was one that was tested at offical NEB tests. In the text it promotes the power-ajusted rear wheels for the utility and the old tryed and true rack and pinion ajustments for the row crop.
But under wheel oppitions for the ROW-CROP, it states that the tread for the rack and pinion rear wheels were from 56" to 96" and the power ajusted tread was 56" to 80".
The parts for the power ajusted rear wheels on the 2010 ROW-CROP were the same as the opitional power ajusted rear wheels offered for the 530. Just like on the 530, most 2010 ROW-CROP owners went for the rack and pinion rather then the opitional power ajusted rear wheels.
On the other side more 2010 Utititys had the opintional power ajusted rear wheels rather then the standard "slide-out hubs" wheels. The "slide-out hubs" on the utility had wheel tread of 53" to 96, or 53" to 106". With the steel disc wheel option on the utilitys, the tread was 64" or 84", depending if they were dish in or dished out. (no other tread withs could be had with thoses wheels. The power ajusted wheels on the utility had the same tread with as the power ajusted option on the ROW-CROP 56" to 80".
Side note. The flat top fenders on the ROW-CROP were an option just like as they were on the 30 series tractors.
Stan - Florida
01-01-2004 08:25:06
I'm reading your post to mean that your tractor does have power-adjusted rear wheels, correct?
I'm sorry I can't help answer your question, but I'm looking at a sales brochure for the 1010 dated 8-63 (don't have one on the 2010) and now I have a question for you.
The brochure talks about Power adjusted rear wheels being an option for the Row-Crop Utility, but not for the Row-Crop tractors that have the 36" wheels. I'm then assuming that the power adjusted wheels were an option on the 2010 Row-Crop but not on the 1010 Row-Crop. Is this true?
Thanks,
Stan
