70 LP not running right
Scott in SC
01-01-2004 06:40:01
Have a 70 LP that runs fine one minute, and seems to be starving for fuel the next.It backfires through the "carb".It will straighten up again for a few minutes, and then start backfiring again. Any ideas???
Jim B in AK
01-01-2004 19:33:36
 Re: 70 LP not running right in reply to Scott in SC, 01-01-2004 06:40:01
See later post by Billy about LP and make sure the air filter is clear and clean. It is probable cross induction firing.
Jim B in AK
Van
01-01-2004 07:02:44
Check the diaphram in the regualator and also the regulator for water flow. Does it do it on liquid or vapor, or both?
Scott in SC
01-01-2004 07:18:50
 Re: Re: 70 LP not running right in reply to Van, 01-01-2004 07:02:44
It does it on both, but worse on vapor.It started running rough only on vapor, and would even out after it was switched over to liquid, but now it does it on both.I never had any trouble with it until the weather turned cold.
tank
01-01-2004 08:23:15
 Re: Re: Re: 70 LP not running right in reply to Scott in SC, 01-01-2004 07:18:50
Check your ignition first.Propane needs a hotter spark for ignition than gasoline does.I would look at the coil first.
Scott in SC
01-02-2004 04:03:57
 Re: Re: Re: Re: 70 LP not running right in reply to tank, 01-01-2004 08:23:15
Thanks, I replaced the coil,and no help, but I noticed that the spark at the points was very weak,so I replaced the points and condenser.Runs like a top now!! The thing is , though, new points and condenser were put in about 9 months ago, and it has run very little since then.Why would it eat up points and condenser like that?
tank
01-02-2004 04:52:41
 Re: Re: Re: Re: Re: 70 LP not running right in reply to Scott in SC, 01-02-2004 04:03:57
Is it missing a resistor and sending too much voltage to them? Also if the key is ever left on without the motor running it could ruin them quick.
