Can a clutch driver be turned?
James
01-06-2003 09:33:40
I have an unstyled B clutch driver that has a lot of pitting on the friction surfaces. Can I have a machine shop turn it? If so, how much can they take off?
Thanks, James
Clooney
01-06-2003 13:32:54
 Re: Can a clutch driver be turned? in reply to James, 01-06-2003 09:33:40
James, you can have it trued up at a machine shop but probably shouldn't remove very much. I can't give you an amount to take off but would guess under .010"-.015" per side. If it is just pitted but not rough or warped it will probably work as is with a little sanding. If it is rough or rust textured then it will probably grab & wear the lined plates.
