John Deere Re-build Mod. D
Randy
01-05-2003 12:11:42
I have an 1948 D and was wondering if there is anyone in southern or eastern Colo. or western Kansas, Ok., or tex. panhandle that would be interested in doing the mech. work or any tips I could get if I start this myself. It sat locked up for several years and I now have the motor free. Thanks for all of the help.
Garland
01-05-2003 17:45:51
 Re: John Deere Re-build Mod. D in reply to Randy, 01-05-2003 12:11:42
Randy right here on the board most of us will be glad to walk you thru the tough spots should yo decide to work on it yourself,first of all you need to contact John Deere and get you a parts book,Greg Stephen at Franktown Colordo would be a good place to start and close to you email is [email protected],also for parts email Ron Stephens@ [email protected],or Don Miller @[email protected] hope this helps a little elbow grease you'll have to provide. Garland
Paul from MI
01-05-2003 17:35:39
Randy,
The Model D is a pretty simple tractor. Many don't have starter, lights, hydraulics, or PTO. The only drawback is they are BIG & HEAVY. Removing the crankshaft is a two man job unless you are a weightlifter.I went through mine from one end to the other and it's not too hard. If machine work is needed it takes some looking to find a shop with equipment big enough to bore cylinders or grind cranks. If you got it freed up, the hard part is probably behind you. If you are at all mechanical I'd go for it yourself. Just my opinion. Good Luck,
Paul
