Temp gauge test?
Bguy
01-04-2003 20:03:55
The temp gauge on my 435 doesn't work. How do you test to tell if it's the gauge or the sending unit? Does anybody know if these sending units are still availible from Deere?
John T
01-05-2003 08:42:33
 Re: Temp gauge test? in reply to Bguy, 01-04-2003 20:03:55
B Guy, I dont have any 435 schematic, but the way it works if its what I think it is, is that you apply voltage to the gauge, and the other side leads to the sensor which is just a variable resistance to the case ground into which it is screwed in. Then, current flow from the battery, through the gauge, through the variable resistance sensor to ground, makes the gauge deflect. Therefore, to test the gauge, remove the wire off the sensor and lightly brush it up against the frame and observe if the gauge needle deflects. Dont attach it to ground or hold it there, because it may over curent and harm the gauge. This requires, of course, that the otehr side of the gauge have a voltage source present on it, because if it doesnt, it will never work (if its the type gauge I think it is). A continuity test should show the gauge has continuity, otherwise its bad. Likewise, the sensor has to have continuity, but its resistance varies with temperature. Good luck, Ol John T Nordhoff
wiliie
01-05-2003 08:23:09
Bguy.
KISS- Keep It Simple ----- .There are 3 components to a gauge system, a volt meter, wire, & temp-variable ground switch. Quick & no cost check of gauge- Disconnect wire at sending unit, turn on switch, oberve gauge. Then ground the end of wire- if gauge swings to other end of dial, gauge & wire okay, sender bad. If no change, do same at guage end of wire. Still no change- gauge bad, change- wire bad, gauge okay. By grounding at these 2 points you isolate each component in the circuit. Shouldn't take more than 10 minutes to test.
HTH
Willie
leon
01-05-2003 04:46:18
According to the Deere parts web site, neither the North American temperature gauge (AT12554T) nor the sensing wire which is to be made from a R32007R is any longer available from Deere.
Steve - IN
01-04-2003 22:02:25
Bguy,
The sending unit is basically a thermistor - a resistor that changes its resistance characteristics with temperature - so use a multimeter to measure the resistance when it's cold, then again when it's hot. Zero resistance, infinite resistance, or no change from hot to cold means a bad sender. If it's not zero or pegging the scale, but you want further testing - start the tractor. If your 435 is cold blooded (doesn't warm up too quickly) you might want to just pull it and hold a lighter or match under the business end for a bit to get your "hot" reading.
The temp gauge is basically a gauge that measures the flow of electricity through the sender. You could ohm it out to see if it's zero or off the scale resistance. If it's between 2 and 100 ohms, it's probably OK, but if you don't trust it, I'd hook up a little variable DC power supply and see if it responds. May not have one of those - but probably have some old wall wart AC to DC xformers around from electronic gizmos that failed long ago. Most of these things put out 50 to 200 milliamps, so they probably won't hurt your gauge. First try a 6 volt one from a video game or old tape or portable CD player, then try a 9 volt one from a phone, then try a 12 volt one from some computer part like an offboard modem. In all cases, give the gauge a bit of time to respond. Those things are potted in a world of grease to dampen them - so they look and act more like thermometer than they would if they were quickly showing the fluctuations they're getting from the sender.
Sorry, don't know if either part is still availble. I'd guess the sender is a standard piece of automotive hardware, as JD didn't try to re-invent the wheel on that - but if I was going to replace the gauge (and wanted it to be the right style and say JD), try the local JD dealer first.
best of luck with it --
Steve
