3020 wide front
Rick
01-04-2003 16:21:00
We are needing to do major work on/replace the wide front end on out 3020. Does anyone know of a good aftermarket replacement? Tractor has a 148 loader and often carries heavy loads. Really enjoy the discussion and info on this cite. Thanks! Rick
Jon from Indiana
01-06-2003 15:02:08
 Re: 3020 wide front in reply to Rick, 01-04-2003 16:21:00
You can also use a case wide front up to a 1370, have seen it done change the top saddle that bolts to the tracor and your home free. Cheaper way to go and it tucks back under just a little more and turns shorter, Have seen this on 4020s A 3020 with the shorter wheel base is limited anyway, be sure and use plenty of weight for ballast. Jon
Jon from Indiana
01-06-2003 15:01:13
Brian
01-04-2003 18:53:24
I did see a 5010 wfe under a 4020 don't know where that tractor is or how they did it but it looked plenty heavy.
Rickey
01-04-2003 18:21:01
Hey Rick, do you have any trouble with lack of response from your loader controls when you are using your clutch. I have a 4020 that is giving me some grief. I am also about to mount a loader on my 3020.
I need some do's and dont's concerning the plumbing of the hyd. system. I have just received a quick fix for a hyd problem concening no response at startup.give me an e mail and I will explain if you need it.
Rickey
Rick
01-05-2003 17:39:10
 Re: Re: 3020 wide front in reply to Rickey, 01-04-2003 18:21:01
Rickey,As I understand the system there is a "lift" pump in the transmission which is disengaged when the clutch is depressed. This will "starve" the system. I have herd of people putting tanks in front of the radiator to help with this problem.
JDTECH
01-04-2003 17:23:57
A 4430 front axle is the way to go. However you also need an adaptor plate to go between the 4430 axle and the frame because the orientation of the pivot pins are different. Also the center steering arm will need to be changed. I put several 4630 front axles under 4020's. I believe we got the first one from the salvage yard in Sikeston, MO. I believe you can also get them from Abeliene Machine in Kansas. They have a web site but I don't know it off the top of my head. Good luck.
joe
01-04-2003 16:41:59
I believe that a wide front off a 4430 series tractor will fit. would be alot heavier than the 3020 frontend.
mike
01-04-2003 16:34:56
Hi Rick , Give me call at 816-586-2841 I can help you out, done rode in this rodeo. Thanks mike
Chad Riddle
01-04-2003 20:14:37
 Re: Re: 3020 wide front in reply to mike, 01-04-2003 16:34:56
I don't know where you're located. But there is a large collection of John Deere and others at a salvage yard in Clinton Missouri. Cook Tractor I think is the name.
